Home > Technical (L322) > 4.4 TDV8 injector codes - help please
Page 2 of 3 <123>
GraemeS
Australia
Maybe the original hoses can be removed without lifting the chamber but not silicone hoses as they're too stiff, requiring all 4 to be slid fully onto the chamber clear of the manifolds.
Post #569065 6th Oct 2020 10:22pm
MAF260
I managed to get an hour on the car tonight, made decent progress
I couldn't see a way to avoid removing the donut so just cracked on with it as I want to clean things as I go. Will need to pick up some suitable cleaning products tomorrow - any recommendations of what to use please? I have a branch of Halfrauds locally.
I'll update progress tomorrow; I'd forgotten how much I enjoy doing this sort of thing!
Post #569071 6th Oct 2020 10:57pm
GGDR
normally I'd say brake cleaner but if cleaning parts on the car not too sure.
You wouldn't want anything ingested....
Also be careful of the coolant pipe near radiator with the little t junctions (just near your yellow rag)
They snap if you look at them wrong...
. Cheers, Greg
Post #569072 6th Oct 2020 11:05pm
MAF260
Thanks, Greg.
I'm painfully aware of the pipe's fragility - found out the hard way when inspecting a failed belt tensioner. The new top hose is only a few months old, but still treated as if made of the finest bone china!
Post #569073 6th Oct 2020 11:07pm
MAF260
Help please...
I can't see a way to remove this pipe from the donut:
The workshop manual seems to show it being removed intact from the 'bracket' on the donut:
Given my previous history with this pipe I really don't want to damage it, so am being ultra-cautious maybe?
Any clues/hints/tips/abuse welcome!
Thanks
Post #569157 7th Oct 2020 7:54pm
GGDR
not done this myself and I'm sure somebody who has will be along soon...
two thoughts though:
are the indents a squeeze point?
the oil drain pipe is a bit like this (but admittedly has more obvious squeeze points
what about the green tabs?
do they poke in to release?
. Cheers, Greg
Post #569158 7th Oct 2020 8:08pm
t5pete
There a tab you have to push in and then pull up.
Post #569163 7th Oct 2020 8:29pm
t5pete
As the top picture is now there's a green tab
Post #569164 7th Oct 2020 8:31pm
MAF260
Sorry, forgot to mention the tab!
I've pushed it all the way in and I still can't remove the connector. I've tried lifting it, twisting it while lifting and it just won't come free. I can't use much force as the pipe is so prone to easy damage.
It's the last thing stopping me from from continuing the job! All of the new silicone replacement pipes are cut and ready to go back on after it's all had a major clean.
Thanks for the replies so far. Maybe there's a knack to it?
Post #569166 7th Oct 2020 8:45pm
MAF260
Odd thing is the workshop manual seems to suggest the whole thing can be removed from the donut without separating the pipes. Given it's a water pipe I don't know if the system will need bleeding afterwards if I do need to separate them?
Sorry for a all the questions!
Post #569167 7th Oct 2020 8:47pm
t5pete
It 100% separates ill see if I can find the old pipe I replaced on mine regarding bleeding no all should be fine I didn't have to bleed the system after removal.
Post #569171 7th Oct 2020 9:20pm
t5pete
Just been out to work shop and got you a couple of pics
Post #569174 7th Oct 2020 9:35pm
MAF260
That's very kind of you, thank you.
I looked at a photo of a new donut and could see that the whole pipe can indeed be removed without being separated. I gently prised it forward out of the slot and it's now free. I have one last plug to disconnect which is fighting me and then I can start the clean up and replace the faulty parts.
Next instalment tomorrow, no doubt.
Thanks again for all of the advice.
Post #569179 7th Oct 2020 9:48pm
t5pete
No problem I hope the new hoses sorts your issues.
Post #569180 7th Oct 2020 9:50pm
MAF260
Hoses are now replaced and everything got a major clean while it was disassembled. It's a wonder the engine runs with that much crap being recirculated back into the inlet.
I will have the codes cleared tomorrow and hopefully report a car back to full health!
Thanks again to everyone who took the time to offer help and advice.
Post #569300 9th Oct 2020 3:09pm
Page 2 of 3 <123>
