Home > Technical (L405) > Help, not unlocking via remote. Cannot switch off alarm .
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Lads,
Went to move it, no response from both fobs, car has a new battery, was on the ctek a few days ago so all good. Where do I start ?
Post #569101 7th Oct 2020 10:27am
leave it for about half hour then try again..
if that dont work open it with the key... ... - .- -.
Post #569106 7th Oct 2020 10:49am
Mr Tee
So managed to start with key held beside steering column. Stopped it and will neither lock nor unlock , I’ll fire in the IID, looks like this is my first issue in 2 years .
Post #569107 7th Oct 2020 10:50am
Mr Tee
No faults just the Std p040
Post #569108 7th Oct 2020 11:04am
next step would be to replace the battery in the fob..make sure its a duracell, they seem to work best.. ... - .- -.
Post #569114 7th Oct 2020 11:50am
Mr Tee
Lol, done that Stan just back from sainsbury . Sadly no change, battery disco next I think, only thing left ..
Post #569121 7th Oct 2020 12:41pm
charlie croker mk2
99% certain that if you disconnect the battery under the boot floor for 2 mins this will re set everything . Running a diagnostic scan probably won't reveal any faults , put the tracker into service mode first !
Post #569127 7th Oct 2020 2:01pm
Mr Tee
no tracker, well don't think so, away to disco the battery.
Post #569141 7th Oct 2020 3:51pm
charlie croker mk2
Standard fit one ? , log into your "in control " account and go to vehicle settings / remote / secure tracker . Turn of while you disconnect the battery .
Post #569143 7th Oct 2020 3:56pm
Mr Tee
Car too old for in control. Battery disco worked, have bokked into MD earliest appointment is 2 weeks out so will report back.
Post #569151 7th Oct 2020 6:45pm
Goodfella
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
WTF is a battery disco?
Post #569160 7th Oct 2020 8:16pm
Mr Tee
Disconnect
Post #569161 7th Oct 2020 8:16pm
charlie croker mk2
Excellent news that it worked , don't waste your money on taking it anywhere for them to tell you NFF ( no faults found LOL )
Post #569176 7th Oct 2020 9:38pm
Mr Tee
Airbag light on too, will see what Indy says before cancelling . Just a bit nervous it goes tits up whilst out.
Post #569177 7th Oct 2020 9:40pm
charlie croker mk2
Ahh the air bag light is on so it definitely needs scanning . Best of luck .
Post #569178 7th Oct 2020 9:42pm
