![]() | Home > Technical (L322) > Sudden brake fluid loss. |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Favourite place to leak are the rigid brake pipes running front to back in way of the left hand sill of the vehicle. May have to remove the plastic sill cover to see properly. Previous cars:
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Thanks
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
And have a check on the steel pipes that run down the rear wishbones... BIG failure point! |
I saw some dirt there too.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
It is shocking isn't it.
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
Yup sad but true.
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Did mine about 2 years ago as all the pipes were shot. Then after had a new rear hose metal coupling fail and was lucky to get to the garage to get it repaired ! |
Exactly shocking. Bent sections are more prone to dusting i guess. While bending there may be micro scratches inside and outside. Direct lines won't suffer rusting as these parts. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
First I knew of my rusty front to rear pipes was when they burst during an emergency stop |
