Home > Maintenance & Mods (L322) > Head light removal on L322 2012 4.4 td
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Has anyone removed the front light assy to change bulbs. i removed the grill and three bolts that I could see but it would not lift out? No room in the engine bay so it has to be removed somehow. Must be missing something so anyone actually done this. Bow down Bow down
Post #569303 9th Oct 2020 3:28pm
you can change the xenons without removing the headlights.. ... - .- -.
Post #569304 9th Oct 2020 3:46pm
mjdronfield
From my manual....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #569306 9th Oct 2020 4:18pm
Nylands
Many thanks Stan and PJ for the posts. With my MOT due shortly I checked that all lights were working today. However I took the view that there would not be enough space to withdraw the Xenon unit and bulb. This led to my attempt to remove the whole unit should I need to change bulbs. Great news if the is enough room withdraw them. Youtube covers the sport models which looks to be easy and I didn't fancy taken out the air filter cases.
Maybe just a bad day!
Thanks both
Dave
Post #569317 9th Oct 2020 5:55pm
CUE99T
So not sure whats in front of them in an L322 from memory but the L405 has an air-box (either side in my car) and you just have 6 screws, then loosen the jubilee clip and it pops out with a bit of mild brute force away from the wing.......deffo a lot easier when I did it this time than squeezing my hand into a ridiculous small space with a HID bulb! all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #569318 9th Oct 2020 6:20pm
Nylands
I’ll take another look tomorrow at the filter areas. as I did think I might just damage a good xenon trying to remove one. Good to be prepared when the time comes.
Thanks for the update.
Post #569329 9th Oct 2020 9:20pm
CUE99T
This is for the L405.....was super helpful.....
Thumbs Up all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #569330 9th Oct 2020 10:47pm
CUE99T
This one shows taking the airboxes out from the wing better.....didn't think it would be identical for a Sport but it is.
2006 Vogue
2004 Vogue
2001 Vogue
Post #569334 9th Oct 2020 11:19pm
Nylands
Well took another look at the L322 light ass'y / Filters. Changing the Xenon bulb looks impossible but Stan is absolutely ring! i imagined a bulb of greater length than it is!! It came and went back in without a problem with careful handling. So its thanks to everyone - knowledge is a wonderful thing.
Glad members have it.
Dave
Rolling with laughter
Post #569480 11th Oct 2020 10:44am
Nylands
Add on:
Dare I ask, is the main beam bulb H7 removal straight forward as room to get one out but not enough to be able to see how it is held in? Not on a pod in the 2012 Westminster, I imagined a replacement with that wouldn't present a problem but i cannot feel any springs to pinch.
Any help appreciated.
Dave
Post #569486 11th Oct 2020 12:06pm
GraemeS
Australia
Easier than removing the bumper to remove the headlight assemblies!
Post #569487 11th Oct 2020 12:08pm
Nylands
I think it must be without doubt but will it come straight out or need a twist etc.? Will need to change filters in a month so maybe get a look in at that point.
I have a habit of breaking things unless I know what I'm doing.
Post #569493 11th Oct 2020 1:15pm
the H7 bulbs are held in by a spring type thingy from memory..you dont twist them like the xenons.. ... - .- -.
Post #569508 11th Oct 2020 4:34pm
Nylands
Thanks again for your help Stan. I will probably bring forward the filter change which is nearly due and take another look when the cover and pipes are removed. You never know when a bulb will go and who needs a panic when it does. Nice to be prepared.
Thanks
Dave
Post #569518 11th Oct 2020 5:34pm
CUE99T
On the L405 theres a little "lever" at the side of the bulb and as stan says you dont twist the bulb but you just firmly push the lever tab (clockwise from memory) and they then come out easily. if you don't do the slide of the clip as such then they wont come out.
Mine was a bit sticky one side and loose the other. all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #569536 11th Oct 2020 7:46pm
