![]() | Home > Maintenance & Mods (L405) > Adblue 65 plate |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
It will tell you when it’s low, but if you look in the service menu on the dash (Ignition on without pressing the brake, press left steering wheel menu button, scroll down to service menu) it should tell you how long unroll it needs filling.
Bricktop1000 Member Since: 02 Oct 2020 Location: England Posts: 10 ![]() ![]() ![]() |
Excellent!
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1115 ![]() ![]() |
https://www.fullfatrr.com/forum/topic39769...t=add+blue letters not necessarily in the right order |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
The adblue tank on FFRR is circa 18 litres and when its full it will show 18 to 19000 miles to empty . The more right foot you give it the shorter the range to empty but as adblue is widely available its nothing to worry about . But you should delve into the service menu even if its just to find the current situation !
Anyone know what the capacity is?
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1279 ![]() ![]() |
Ad blu is ad blu no need to pay for any other name such as shell .
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
On the wifes Evoque its about 1L per 5-600 miles....it will tell you when its about 1000 away from being needed I think.....
Thank you all for your reply’s. Much appreciated |
Be warned the sensors dont pick up that you have added 2 liters when it said you have 500 miles left and if the front of the car is higher than the rear it will not restart. letters not necessarily in the right order |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 802 ![]() ![]() |
I didn’t know how full it was when I bought the car, but I’ve just put 10 litres in as the app said I had 900 miles left and could add 2.2 gallons. Only showing 4,225 miles to go. Maybe it will increase when I drive it? MY23 Panamera E-Hybrid
Checked on mine and it said I had about 6500 miles to go, put 11 litres ish in and it now says 19500 to go. Will keep an eye and see how many miles we actually get out of it! There is nothing that can't be fixed with a hammer😜😜
