![]() | Home > Technical (L405) > Battery Charging |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1406 ![]() ![]() ![]() |
That seems inconsistent with the owner's manual, at least going by ownerinfo.landrover.com for my model year. If you want to connect a trickle charger the easiest thing if you have tow electrics is to get an adaptor from the forum shop and plug the charger into the adaptor with the adaptor in the tow electrics. That worked well for me during the lockdown.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8020 ![]() ![]() ![]() |
I've hard wired a CTEK connector to the under bonnet posts.
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
SO my car has dual battery system. This is what I am reading:
Anyone know if applying charge the post under the bonnet charges both the Aux and Primary battery?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
Jack this is for the workshop when diagnostics are being used sir... There must be a suitable battery tender/charger attached when software upgrades etc are performed, for obvious reasons |
You charge both batteries from the front post yes sir... |
Thanks Cam-tech for clearing it up.
Item
No sir you do NOT want the ign on... It will turn itself off after just a few minutes anyhow! |
The key will be how that power distribution box works.
Thanks Cam-Tech, Alistair.
