![]() | Home > Technical (L322) > Second battery |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 188 ![]() ![]() ![]() |
I have In my 2010 tdv8 |
Not fitted as original. Mine has a second battery fitted, can be very useful. DIY but pro. |
Billie Member Since: 12 Oct 2020 Location: south-west Posts: 49 ![]() ![]() ![]() |
Thanks for that, good to know mine is not on its own. I presume it is for the entertainment side of things. Would I be right in saying, if I remove the main battery I will not lose the codes |
I can only speak for my 2004 but when changing the battery no codes etc lost at all. I presume it is the same for all years as I've never seen a post regarding a problem. |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
I would suggest it's "electrically unlikely" that removing the second battery would cause you to need to re-enter any codes, my logic being that the cars electrical systems are 12 volts and hence, the batteries must be wired in parallel.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
There are no audio codes sir... Left them things behind with the P38 ![]() |
"There are no audio codes sir... Left them things behind with the P38"
