![]() | Home > Maintenance & Mods (L322) > Air Suspension, Inactive |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
Hi you say the car looks low is this having just stood or is it low on driving the car and if you drive do you get a warning of speed in acsess mode ? |
Wiggins Member Since: 27 Feb 2011 Location: Glasgow, Scotland Posts: 94 ![]() ![]() |
no, nothing warns me anymore it used to but no the lights are not even on the lowering switch |
Don't get me wrong it looks good but I don't think it can be good for the car |
As i thought the system has gone into hard lock out this is probley due to compressor failure the you will require a reset from a dealer or indy as you cannot reset yourself then a check on the compressor you can check the compressor yourself by unpluging the connector in the wheel well and applying power to seeif it works |
great thanks alot |
Sorry about that but i do remember recovering from this some time ago by shorting my compressor wiring out to pump the car back up to normal ride height but my problem was that the compressor was working but not producing air so i stripped the compressor refurbed the bore reassembled then ran it by a jumper on the plug |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8065 ![]() ![]() ![]() |
Happened to me a year or so ago - I needed a new compressor. |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
under the bonnet on the drivers side right up the back near the kick panel is a valve with lots of pipes in it mine had for some reason poped a pipe out maybe check there as well "RANGEISM WILL NOT BE TOLERATED"
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
oodathort... was that on an l322? If so where did you get the parts please? 2010 Disco XS TDV6, 2009 Freelander 2 GS
Yes on a L322
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
is your car a facelift with touch screen etc? |
Now that has my interest - Is it like a piston ring type seal? If this something you did on a lathe? When you say PTFE I have a vision of a roll of plumbing seal.. but can't imagine that lasting long in a compressor. I ask as I've been holding out for an overhaul kit but looks like I need to bite the bullet soon.. Faults popping up every few weeks now. 2010 Disco XS TDV6, 2009 Freelander 2 GS Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy". |
BigJ Member Since: 16 Mar 2011 Location: North Yorkshire Posts: 247 ![]() ![]() ![]() |
I remember seeing a YouTube video on how to reset this.
bjs Member Since: 27 May 2010 Location: Surrey Posts: 54 ![]() ![]() ![]() |
I had this last week, went into Challengers in Tongham, the Autologic thing said compressor was faulty... New compressor fittted and fault still there, it turned out to be a faulty valve switch or something on the front left... They stripped it and put back together and now works perfectly....sadly a bit of labour but the new part was sent back and the old compressor re fitted... B |
