![]() | Home > In Car Electronics (L322) > ctek charger |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995
I’m sure that if the battery isn’t flat, that will be fine to keep it topped up and maintained.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348
I have the mxs 10 as it also has the Supply Mode feature to allow a clean 12V for powering the car when doing diagnostics etc.
| Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508
| Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351
As a rule of thumb, if the battery is 12v (which I believe they all are), then the only difference will be in the time it takes to charge the battery, it will still charge.
| Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529
+1 for MXS-10 excellent and as said he supply mode is very useful for valeting or diagnostics etc.
| 400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65
I have the CTEK 5.0 and connectors on all the cars so that I can plug them in and keep them topped up. Having the connector hard wired to the battery means that even if they are outside, I can hide the mains plug and unit under the bonnet, out of the weather. Rob 05 L322 4.2SC
| Classic Matt Member Since: 05 Sep 2020 Location: West Sussex Posts: 72
Interesting point about the pre-heat - can it be used with a battery conditioner attached? Or does that depend on the conditioner? |
I’ve had no issues charging mine from the towing electrics. It has also been fine when it’s been connected and I’ve used the fuel burning heater.
Good to know - thank you.
Thanks for this, hadn't thought of that but yeah, it's definitely possible. I'd hope the difference would be so small as to not affect the charging, but it probably depends on the gauge of the cable used - I can't imagine it would be an issue. Easy to check with a DMM, check the voltage at the battery and compare to that at the towbar! The ctek looks handy as it also has a 10amp power supply, which would make it useful when camping as I could run my little electric coolbox off the mains hook-up, so that's another little bonus |
