![]() | Home > Maintenance & Mods (L322) > LED Hi-Beams - With Pics |
So, in comparison they look fantastic. Looking at the photos though it seems the halogen is still quite a lot brighter ???
Wiggins Member Since: 27 Feb 2011 Location: Glasgow, Scotland Posts: 94 ![]() ![]() |
just ordered the 120, great find! |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
Thanks Dan, all ordered |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I might order some when a new release of Navcoder can actually talk to the LCM and turn the DRL's off.
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
I thought Nav coder already did.. turns them on and off on my '03 with the option of sides, heads(flash) at certain percentage of brightness for that "moody" look |
my navcoder can talk to and programme the LCM V8 facelift Range Rover Autobiography 22" wheels.
Ahh, sorry, I should explain, the original version of Navcoder I had coded the LCM fine, then, after a few months, there were several updates, last time I tried to connect to the LCM to turn off the DRL's, I clicked read, then the DRL option was unavailable so I couldn't turn them back off. I think there's been an update since so I'll try turning them off again. 2006 Mercedes CLS
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35830 ![]() ![]() |
the bigger ones wont fit through the main beam hole DAN, only the 18's fit....i have 18's in my 'main beam' and use them as drls [with switch] and i have put the bigger 68's in my fogs [use as mains].. ... - .- -.
Odd - my 18's were originally for my fogs but they wouldnt fit through the hole! Yet they fit fine in the main beam? ![]() |
my 18's fit the fogs and obviously the mains but the bigger smd's dont fit the mains cos the cluster diameter is to big...
hi, here is a video of my 2006 test lamp with the 68 led bulb 5500k fitted,
That's pretty damn bright! 2006 Mercedes CLS
More pics:
hi, in all fairness you dont get as much light projection as with the halogen but as i drive in london most of the time its not a prob i get plenty of light from the bi xenons, what i do like is the fast response they give,instant on and off, may be the 120's will give more projection.. V8 facelift Range Rover Autobiography 22" wheels.
