Home > Technical (L322) > Restricted Performance & limp mode |
Sharky1168 Member Since: 21 Jul 2015 Location: Rochdale Posts: 23 |
Hi guys, I have a 2010 MY 3.6 V8, which developed a fault on the way home from work when I accelerated to overtake a slow moving car and the dashboard light up like a christmas tree! Restricted performance mode message with the limp mode restricting the car to 15 mph....even with my foot on the floor. Stopped the car and restarted, but the car wouldn't reset. I manage to drive most of the four miles back home, then gave up when the 'traffic jam' behind me started to honk, and walked the rest of the way. Started up the next morning, but in restricted mode again. As it was under 'warranty' I rang the dealer and had it delivered back to them. Now they are claiming that it was my fault because I drove the car in limp mode!! Is there a 'recommended' time or distance that the car can be driven safely by Land Rover? Reading the forum, the fault looks to be one of three 'simple' things, but I feel the garage are trying to pull the wool. Anyone who can help or find the offical advice from Land Rover when this happens? Thanks Current RR L322 TDV8 VOGUE
15th Oct 2020 10:12pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4218 |
They are taking the basically
16th Oct 2020 8:39am |
Thanks for your input guys, the mechanic who works for Farnell thinks the turbo may be shot, but I am sure that it wasn't because it was driven such a short distance in limp mode. Methinks a strongly worded letter is on the cards...along with a rebuke for being such . Thanks again Current RR L322 TDV8 VOGUE
17th Oct 2020 11:51am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
Limp home mode is just that - the car has detected a fault and is allowing you to get home albeit at a reduced rate.
17th Oct 2020 12:39pm |
And that is why we all avoid main dealers and use specialist independents 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Oct 2020 3:58pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Did they read the error codes and tell you what they were?
18th Oct 2020 7:07pm |
