![]() | Home > Wheels & Tyres > Up a size? |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Just from what I have read , 40 is the biggest you can go but 285 40 22 fits fine 2015 4.4 AB
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
Theres a shame i was hoping for a little extra rubber
The 285 40 22 will give a bit more sidewall 2015 4.4 AB
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818 ![]() ![]() |
This ^ and the spare will fit in the boot well / I can confirm from personal experience 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2720 ![]() ![]() ![]() |
That’s quite a lot of tyres over a short period, have you had the tracking done? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
Plenty of options for extra rubber, but it means smaller wheels.
ive had the tracking done and it was not far off tbh, always the outside edge that wears the rest of the tyre has lots more tread |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
Just sounds like you drive it like Alistair and me....like a sports car....lol
not really its just wider.....still needs to be same size as rear......unless you change all 4..... I think you'll need to go down to 21's if you want a 45 or more profile..... I had been told in the past that the profile is kinda predetermined and needs to match the wheel size diameter...not so much the rim width....as Craig has 285 I think on his 23" but Khan suggest 305....so its obviously ok to alter the width a bit but diameter not so much. Keen to see what you do.....I'm kinda there too.... all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
A 285 40 22 will give you a 4mm taller side wall over a 275 40 22 side wall. Obviously not huge but an increase none the less. Smaller wheels are an option if you are happy with the aesthetics and the handling. Personally I prefer the look of 22s and the more positive feel handling wise but each to their own in both departments. 2015 4.4 AB
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 556 ![]() ![]() |
Change to Pirellis. The Conti's wear just by looking at them! Tony
dont get that......can you explain? all smug in my new plug! 2021 Westminster Black D300 2013 Vogue SE - gone Some Porsche Cayenne guff pretending to be a 4x4!! 2006 Vogue 2004 Vogue 2001 Vogue |
Dave G Member Since: 30 Jul 2020 Location: Dorset Posts: 84 ![]() ![]() ![]() |
If memory serves me right the sidewall is calculated as a percentage of the tyre width?
The 285 part of the 285 40 22 is the width in millimeters the 30 is the aspect ratio ( percentage ) of that width and the 22 is the diameter, so a 275 40 22 tyre would be 275 mm wide with a 110 mm sidewall and a rim size of 22 inch. A 285 40 22 would be 285 wide with a 114 mm sidewall and a rim size of 22. 2015 4.4 AB
