Home > Technical (L322) > L322 8HP 4.4TDV8 Gearbox Failure |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16192 |
There are a few threads running on here about the ducting splitting on the top/backrest peltier motor sir... That seems to be the favourite issue stopping the seat heat/cooler working correctly... |
29th Apr 2019 10:29am |
Landyandy1765 Member Since: 25 Mar 2019 Location: bournemouth Posts: 56 |
i repaired my seat cooler / heater . i ordered off Ebay a Pelitor unit from America DU5Z-19N550-D . same item as a range rover but in a different shape . same size pelitor and transfered it to the range rover sead . £50
18th Oct 2020 4:39am |
OO__OO Member Since: 15 May 2014 Location: Manchester Posts: 18 |
Thanks Landyandy, I'll look into the peltier though I'm sure I've seen a write up somewhere of someone doing the same thing without success. It required a bit of rewiring as well.
18th Oct 2020 3:21pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Landyandy1765 could you post more details of your seat repair and part here pls:
18th Oct 2020 4:04pm |
i have some pics and the peletor unit is the same just in a different shaped housing . very easy to sort out . the hardest thing is the removal of the seat and stripping it . mines been working fine now for 12 months. ill post the seat pics and the units for you to see .
18th Oct 2020 6:16pm |
Just an update, the gearbox is still fine.
2nd Jan 2021 3:17pm |
