![]() | Home > Maintenance & Mods (L322) > Intermittent Heavy steering |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2724
Servotronic valve the likely culprit, worth a search |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Mr Tee's right. If not that it could be the BCM intermittently failing (it's under the Pax seat). |
| jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299
To be fair I know about the BCM issue as my car is experiencing that as with rear doors don't open sometimes and the steering is very heavy when both doors don't open also.I can bypass this by quickly turning ignition on and off. My issue is that I get intermittent heavy steering when driving sometimes light and sometimes heavy resistance. When I rev engine at 3000RPM when stationary I still get this issue turning left to right full lock intermittent heavy resistance. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
| All times are GMT |
