Home > Maintenance & Mods (L322) > P004b
Ranger oc
United Kingdom 2011 Range Rover Autobiography Black 4.4 V8 Santorini Black
P004b
P004b -turbo/supercharger boost control solenoid B actuator stuck any ideas guys . Where do I start looking
Post #570436 20th Oct 2020 8:55pm
GGDR
Welcome!
Despite the code pointing to the actuator, I would be looking at donut and other boost hoses.
Boost leaks can and do show up as actuator faults. If low boost is detected (perhaps cause by leak) the ECU can think it's the actuator.
Anyhoo, search 'donut hoses'. Boost leaks are very very common on the 4.4
Good news though is that if it is a hose, they are very easy and relatively inexpensive fixes.
. Cheers, Greg
Post #570443 20th Oct 2020 9:39pm
Ranger oc
Thank you for info
Post #570450 20th Oct 2020 10:22pm
rjff
As Greg says, Welcome and it could be the donut hoses.
Page 4 in this thread helps
https://www.fullfatrr.com/forum/topic52807-45.html.
AND if you are poking about in there, watch out for the small connectors on the top rad hoses, they can break easily and it's at least £80 for new ones!!
Items 3 & 3a Cheers
Richard
Gap IIDBT
Post #570485 21st Oct 2020 11:38am
