![]() | Home > Maintenance & Mods (L322) > Hilka 2 Tonne Car Ramps |
| V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381
Total vehicle weight about 2.7 tonnes so either axle load will be less than 2 tonnes......but how much do you value your life? When it comes to safety I always prefer to air on the side of caution. Not worth taking the slightest risk. I bought higher spec axle stands for this very reason....if they fail it could be too late for you , a loved one or good mate especially if you also think of additional forces from pulling on stuck nuts etc. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
| dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450
I'm with you there Bob hence my question. I'm normally an axle stands man as a minimum usually as it's too easy for things to wrong very quickly. Unfortunately on this occasion my car is on a slight gradient which would mean the axle stands not being at a right angle between floor and car and that gives me no confidence at all. 2011 TDV8 Vogue SE |
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
The safe working load already has a factor of safety built in (normally something like 4 times the SWL) so a 2 tonne ramp or axel stand should easily and safely coupe with a 2 tonne static load. The question should be is the item from a none manufacturer with a good reputation and the correct quality and safety certification, if so you are good.
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
They will be fine. I use similar ramps myself. If you feel nervous, pop some stands under too as a belt and braces approach. Kev
| All times are GMT |
