![]() | Home > Technical (L322) > 10-12 deployable sidesteps wiring loom |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102 ![]() ![]() ![]() |
Not completely sure -- the 2010-2012 fitting instructions PDF is in the wiki under the 'Body' section. Current: 2011 FFRR Vogue SE 4.4 TDV8
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
The instructions that have information for both models only shows a few extra wires at the button.
Having only fitted a set to a 2011, I suspect you'll struggle without the correct wiring harness. Current: 2011 FFRR Vogue SE 4.4 TDV8
It seems the diagrams are different. However using the 07 loom and 10-12 ecu I have got it to work.
The switch is important -- enables you to enable and disable steps -- locked in, or out. Current: 2011 FFRR Vogue SE 4.4 TDV8
Turns out there was a switch in the bundle of parts. I had ordered one.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
I bought the loom and ECU in anticipation of getting the steps from John Craddock. After three months waiting they said they couldn’t get them anymore.
During my search I found another set for sale. They wanted £350. I can get contact details if interested. |
