![]() | Home > Technical (L322) > Air Bag Light on. 2007 Vogue SE (Fixed) |
KDavies3 Member Since: 03 Jun 2020 Location: South Wales Posts: 4 ![]() ![]() ![]() |
Just for anyone interested, I fixed the problem.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
thanks for the update.. |
DanRRL322sc Member Since: 16 May 2022 Location: Bedfordshire Posts: 55 ![]() ![]() |
I’ve got the same problem on my 2007 SC. I don’t suppose you know the part number for the replacement?? Thanks. |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 ![]() ![]() ![]() |
Same problem just popped up on my 2013, 405, not sure where the sensor is yet 😡 |
Job done!!! I put the scanner on it and it was intermittent power interruption to SRS sensor. I disconnected the battery, touched the + and - leads together to dissipate any charge, cleaned up the terminals and the connectors, put it all back together. Started the car, steering lock full both ways a couple of times, switched off, cleared the fault, re-tested and now all is good |
