Home > Technical (L322) > Air flow / flaps issue
ebajema
Hi all, I accidentally found out what my AC issue may be. I noticed that only one vent was flowing cold air unless the car is parked facing downhill, that is when all the others come on as well.
Anybody have some suggestions on what that could be caused by and how to solve it? Summer is approaching and I would like that to all work Smile. MY 2010 5.0 SC Galway green and sand interior!!
Post #570601 22nd Oct 2020 6:05am
ebajema
Update. It is working again by the feel of it. I went skiing today (3.5 hr drive each way) and it worked perfectly fine.
Yesterday I checked fault codes, none in that system.
So I did two things :
- used canned air to blow dust off the temp sensor (no idea how much was blown off though, just stuck the hose thingy through the little grille).
- I pulled fuse 62 and put it back in, I heard the flaps moving (assuming it is the calibration cycle).
Since it has worked fine. Will keep you all posted! MY 2010 5.0 SC Galway green and sand interior!!
Post #570862 25th Oct 2020 9:11am
ebajema
Alas, that wasn't it. Right now it is back to how it was, just cold air out of the passenger and center passenger vents only. MY 2010 5.0 SC Galway green and sand interior!!
Post #570966 26th Oct 2020 9:40am
ebajema
Does anyone know how to remove the little grille that sits in front of the internal temp sensor? I want to try and clean the sensor and see if that makes a difference. MY 2010 5.0 SC Galway green and sand interior!!
Post #571122 28th Oct 2020 11:35am
Gsxr1250dave
I just fixed these blend motors have a look at my old posts I will check my photos and see if I took some of me doing it
Post #571131 28th Oct 2020 1:30pm
