![]() | Home > General > l322 model help |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
hi all how can you find out the true model of a l322 with out the vin number |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Certain models were only available at a certain time.
This is in the Wiki....
https://www.fullfatrr.com/wiki/Range_Rover_L322 2011 Range Rover Vogue SE 4.4 TDV8
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
i had a 2008 4.2 SC as an autobiography so they are about.. ... - .- -.
hi stan did it state on the v5c that it was a autobiography model |
Stan, Did it have a leather headlining like the later ones? Just trying to see if there is a definite way to tell. 2011 Range Rover Vogue SE 4.4 TDV8
davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63 ![]() ![]() |
Why not ask for the vin then you can check it? 2004 4.2 SC Japan Spec
i am afraid it is not as easy as that if you ask for the vin they think you are a scammer and will not give it and even if you ask them to do it they dont get back to you |
yes it did say AB in the V5 and it didnt have a leather headlining...
What about the registration number? 2004 4.2 SC Japan Spec
okay thanks stan so it is stated |
i have got the reg and checked it on car checker sites comes back as estate model |
If it’s the one I can see on AT, its not got anything to make it stand out as an Autobiography. It does have RSE but that was just a normal option.
