Home > Technical (L322) > dead range rover
razzer
England 2003 Range Rover HSE Td6 Zambezi Silver
dead range rover
can anyone help, came out to my range rover this morning and it wouldn't unlock with the fob. opened the door with the key but the steering lock wouldn't come off. checked the battery and it was totally flat. swapped the battery for a fully charged one and no change. remote locking doesn't work and the key doesn't turn in the ignition. also the airbag light is flickering. the radio system died yesterday on my way to work. any ideas anyone.
Post #571379 31st Oct 2020 12:35pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Range rovers take a lot to jump start mate. It's obvious you've got a power drain somewhere or perhaps a dead alternator. I'd suggest get a new battery, and see what happens when you start it up
Post #571381 31st Oct 2020 12:43pm
razzer
it is a new battery, bought it this morning.
Post #571382 31st Oct 2020 12:48pm
You could try connecting a jump lead from the battery -ve post to some metalwork on the engine block and see if it makes any difference.
Post #571383 31st Oct 2020 1:17pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
If not the battery, then could be the alternator.
You did code in the battery didn’t you? And have measured it to check whether it is a good one?
Post #571389 31st Oct 2020 1:57pm
razzer
the fault has now changed, i managed to turn the key and start the car. this i tried 6 or 7 times with success. then the wife and i drove to sainsburys and parked up. when we went back to the car the hazards were flashing they stopped when i open it, but again i couldn't turn the key. after 20 or so attempts it turned and the car started.
Post #571394 31st Oct 2020 2:42pm
Bl4ckD0g
I wouldn’t advice starting the car 6 7 times in short succession and then only having a short journey 😬
Did you scan it for fault codes yet? Otherwise everyone will just be playing a guessing game.
Post #571396 31st Oct 2020 2:45pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
certainly sounds like a battery drain but with other issues i.e. radio failure, air bag light flickering and hazards lights (no alarm?) could also indicate wet electrics as the overall cause. So other than reading fault codes check for water ingress in rear compartments (both side cubbies)and inside by the LCM (Base of A frame) and under seats for dampness around BCM (front passenger seat) If you can, see if either of the front footwells are wet under the carpet by lifting the treat plates.
Post #571434 31st Oct 2020 7:51pm
razzer
sounds like it cold be water ingress, also had ABS light come on air suspension inactive message and rear window winding itself down. all the faults have now gone apart from the radio not working. no sign of water or damp carpets though. is it a major job to remove the glovebox fuse box to inspect it?
Post #571548 2nd Nov 2020 9:32am
