Home > Maintenance & Mods (L322) > td6 oil in expansion tank
wicklowRRirl
Ireland 2005 Range Rover Vogue Td6 Java Black
morning folks ,
while out checking a few bits on RR I noticed there was quiet an amount of black oil in the expansion tank.
oil level has dropped no signs of water in the oil or on oil cap,
is there anywhere else oil could get into the cooling system a part from head gasket failure on the m57?
roughly how many hours are in doing the head, rough cost?
Post #571485 1st Nov 2020 2:27pm
mjdronfield
I’m not an expert, so might not be related in any way..... have you changed the crankcase breather or replaced it with a vortex one from a later BMW?
Usually gets missed when servicing.
More knowledgeable folk along soon.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #571488 1st Nov 2020 3:29pm
wicklowRRirl
I haven't replaced that but will throw it on there growing list Very Happy
Post #571489 1st Nov 2020 3:35pm
mjdronfield
The filter one can get blocked, not sure if that would then send oil where it’s not supposed to be. Fit a vortex one and you will never have to change it again.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #571490 1st Nov 2020 3:51pm
There's an engine oil cooler bolted to the rear of the oil filter assembly. It's a plate heat exchanger, engine oil on one side of the plates, engine coolant on the other side of the plates. It's not inconceivable one or more of the plates has corroded through allowing oil to mix with the engine coolant. Thumbs Up
Post #571501 1st Nov 2020 5:56pm
wicklowRRirl
thanks for the reply ,
that seems like my first try in morning, the oil cooler looks like sh17 from the outside if that's anything to go by hah a
Post #571509 1st Nov 2020 8:16pm
wicklowRRirl
thanks for the replies , after popping off the oil cooler and a few choice words the problem looks like the oil cooler gave in.
now the fun part of flushing out the cooling system
Post #571577 2nd Nov 2020 1:00pm
mjdronfield
Got there in the end. Least it’s easy to get to.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #571580 2nd Nov 2020 1:15pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
I have found the best thing to clean oil out the rad is a tin of petrol injection cleaner, start by flushing the rad out as best you can then fill up and add the injection cleaner run the engine till it is properly warmed up, flush rad again several times with clean water follow up with some proper rad flush (yes its a lot of flushing) and the cooling system will be cleaner than a clean thing on cleaning day, over the years I have had this job on several different cars and it works a charm.
Post #571668 2nd Nov 2020 11:37pm
