Home > Maintenance & Mods (L322) > 2012 Fault - Cruise Not Available / Speed Control Module
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Hi there,
I have an anoying fault thats been with me for the last 6 month, I've finally got around to try and solve it.
There are two Dash Warning Messages and of course the Adaptive Cruise Control does not work.
With the GAP IID3 - I have the following mesage in the Fault Log.
Does anybody have experiance of solving this fault and also know where the SPeed Control Module is located ?
IPC-Instrument Pack
U0104-00 (2F) Lost communication with speed control module
( on 31-10-2020 14:06:26 at 137480 km )
- Test Failed
- Test Failed This Monitoring Cycle
- Confirmed
- Test Failed Since Last Clear
PCM-Engine TDV8 4.4L
( on 31-10-2020 14:06:28 at 137481 km )
- Test Failed
- Confirmed
MY 2012 4.4 TDV8
Post #571542 2nd Nov 2020 8:58am
GraemeS
Australia
The module is behind the front bumper just inwards from the right headlight. You might want to check the fuse in the engine bay fuse box (fuse 17, 10A).
Post #571545 2nd Nov 2020 9:18am
bwelton
Many thanks,
To get to the unit, does the bumper or anything need removing ?
Thx -------------------------------------
MY 2012 4.4 TDV8
Post #571549 2nd Nov 2020 9:50am
GraemeS
Australia
Yes, the bumper has to be removed.
Post #571641 2nd Nov 2020 9:10pm
...or maybe through the wheel arch ? Mike - MPx
Post #571667 3rd Nov 2020 12:09am
bwelton
Can anybody point me at the method or manual for this ?
I can't find any reference to the 'Speed Control Module' within the Workshop Service Manual. Perhaps its under a different name ? -------------------------------------
MY 2012 4.4 TDV8
Post #571702 3rd Nov 2020 12:45pm
GraemeS
Australia
Perhaps described as the adaptive speed control module. Attached is the wiring schematic.
https://www.fullfatrr.com/gallery/albums/u...trol~0.pdf
Post #571825 4th Nov 2020 11:23am
bwelton
Many thanks, -------------------------------------
MY 2012 4.4 TDV8
Post #571826 4th Nov 2020 11:31am
bwelton
Does anybody have either of the following documents for the L322 2010 onwards RHD ?
- Connector Quick Reference Guide
- Range Rover Electrical Library
I’m trying to track the locations of connectors C3618 / C3619 and C2145
MY 2012 4.4 TDV8
Post #690821 18th Apr 2024 9:44am
GraemeS
Australia
https://www.fullfatrr.com/gallery/albums/u...dar%29.pdf
Post #690829 18th Apr 2024 10:46am
bwelton
Many thanks GraemeS.
I’m still trying to track down the problem with MY2012
GAP IID Fault Report.
- U0104-00 (2F) Lost communication with speed control module
I was not sure where those cables route from and to, under the Front Bumper ?
Do you have any other information, pictures, wiring Dia etc you can point me to ? -------------------------------------
MY 2012 4.4 TDV8
Post #690833 18th Apr 2024 11:31am
GraemeS
Australia
I don't have any pictures but the wiring diagram is attached. Mine wasn't originally fitted with ACC and there was a dummy plug in the harness socket clipped to the panel behind the bumper (nothing to do with the bumper) where the radar unit mounts and into which the radar unit's link harness fits.
If the 10A fuse #17 in the engine fuse panel is intact and the 5A fuse #6 in the passenger fuse panel is intact then the bumper will need to be removed to check the connectors and wiring. The radar unit itself could be faulty.
IIRC my biggest issue with R&R'ing the bumper was dealing with the screws at the lower edge of the wheel-arch just behind the liner, that is once I found the screws near the fog-lights.
https://www.fullfatrr.com/gallery/albums/u...trol~1.pdf
Post #690838 18th Apr 2024 12:28pm
bwelton
Just checked the Fuses again #17 and #6 and they are good. So I was just wondering if there is anyway to get to the AAC Control Unit without removing the bumper ? Perhaps from behind the wheel watch liner ?
By the way - I have also pasted below my IID Faults invade there may be a correlation between other Fault Messages. ?
Does anybody have any other thoughts on those Fault Messages ?
VIN: HIDDEN
L322 - Range Rover 2012
Vehicle scanned on 21-04-2024 12:18
Using IIDTool BT V3.0 B2643
BCM-Body Control
B1D17-87 (2F) Bus circuit - Bus signal/message failure - missing a message
( on 21-04-2024 12:17:41 at 175670 km )
- Test Failed
- Confirmed
B10AD-87 (2F) Rain sensor - Bus signal/message failure - missing a message
- Test Failed
- Confirmed
IPC-Instrument Pack
( on 21-04-2024 12:17:45 at 175670 km )
- Test Failed
- Confirmed
IPMB-Camera
B12C1-49 (2F) Right mirror camera - System internal failure - internal electronic failure
( on 21-04-2024 12:17:46 at 175670 km )
- Test Failed
- Confirmed
P040D-00 (2F) Exhaust gas recirculation temperature sensor A - circuit high
( on 21-04-2024 12:17:48 at 175671 km )
- Test Failed
- Confirmed
( on 21-04-2024 12:17:46 at 175671 km )
- Test Failed
- Confirmed
RCM-Airbag
B1127-13 (AA) Passenger's side - side air bag deployment control - General electrical failure - circuit open
( on 21-04-2024 12:17:51 at 175670 km )
- Confirmed
- MIL Requested -------------------------------------
MY 2012 4.4 TDV8
Post #691029 21st Apr 2024 12:25pm
GraemeS
Australia
The radar unit's bracket is bolted to the front of part# LR020912 in line with its RH bracket. Some access might be possible from underneath the bumper if the front undertrays are removed, possibly if just the small RH triangular cover is removed.
Post #691059 21st Apr 2024 10:04pm
