![]() | Home > My Range Rover > Have taken the plunge..... |
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
Have you checked the yellow mis fuelling guard? |
| range366 Member Since: 28 Mar 2011 Location: glasgow Posts: 15
Mis fuelling guard? Can you explain a bit more please? |
| V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381
https://www.fullfatrr.com/forum/topic6435....ellow+boot
Thanks for that, will have a look in the morning |
| rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 569
So, it's not just me then? I've asked the same question because I get the same problem on both of our 2010 4.4 TdV8's and no, the misfuel guard hasn't been operated. It seems to be very fuel pump dependent, some pumps work fine and others are a right PITA. You just have to fiddle around with nozzle angles until it works, or move pump! It could be down to servicing of the pump triggers, as the less used pumps at our local Shell work fine, whereas the more used ones can be problematic. Drives: 2010 FFRR TdV8 Vogue - Stornoway Grey 2010 FFRR TdV8 Vogue SE - Zermatt Silver 1998 BMW E36 M3 GTII |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Turn the fuel hose upside down.
| RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520
I've found that holding the nozzle so that it's parallel to the ground works with mine.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
I picked mine up when I bought it, went to nearest garage to fill with fuel, still there 2 hours later having called the garage out. Still the same 5 years later.... can only put nozzle in a bit or misfuel thing comes on.... right pain.
When I bought it from the car dealer there was 3/4 a tank of fuel in it, which i thought most odd for buying a new car...
| oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397
hi what is old faithful reg would be nice thanks new vehicle purchase
Old faithful reg number is SM52 ZXL |
She drives brilliantly, never misses a beat and has wanted for nothing,.. but, and there's always a but.... she is gonna need a wee bit of work doing to her at some point, so I'm hoping someone prepared to take her on. |
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
I just brought a TDV8 2012 registered March 2013 so i think it may be one of the last of the L322's and i adore it my last one was a L322 TD6 i loved that too but this is a step up and so much better on Derv too |
