![]() | Home > Maintenance & Mods (L322) > Cabin air filter box |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
Take off the engine cover and you will see the cabin/pollen filter housing towards the windscreen. It's about 600mm wide and there are two studs with 14mm AF nuts. Remove and pull the housing towards you.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
No need if you are just doing the battery.
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 193 ![]() ![]() |
Thanks so much for that |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
Not the best of pictures, but here is B.B. with the box removed.
