![]() | Home > Maintenance & Mods (L322) > 2012 seats into a 2007..anyone done this? |
| Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218
If you compare the wiring, the plug in sockets to the various functions are the same but as you have seen there are differences in the control box under the seat. You should be able to leave these in place and transfer your old control box across. I actually did the reverse and all appears to working correctly. I did make sure that i disconnected the battery before swapping. It is worth plugging in a Gap iid to see what faults are showing. |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2300
The problem I see is there is no quad lock or whatever it’s callled with the round pins connector on the new seats it seams to go to another module under the seat? I’ll have another look in the morning but worst case guess I will take the back off and swap the wires Current stable:
I did this on my old 07 putting 12MY seats in... From memory, I swapped the loom, ECU & switchpack over Dan |
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
Glad I saw these posts, I have a rip in one of my ivory seats and some wear so want to replace them, Land Rover are now out of stock of new OEM covers in my colour so after Covid is not a restriction on travel I can find some later seats, should be newer so less age related damage from sun and general wear. 👍 |
Thanks Craig did you just swap the driver insides as the passenger works? I’ve just done the driver seat and all good Current stable: 2015 5.0 V8 S/C AB 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
Yes Dan, exactly the same as you've done sir... |
I’ve read somewhere that even though the passenger seat will work the diagnostic equipment will not be able to communicate with it do you know if this is true?
| Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204
Yup and still great except no heated rear seats though but no one sits in the rear
Zambezi silver Vogue Se unique |
why no rear heated seats? I think mine work?
Mine do work just quickly checked what’s up with yours? Current stable:
| All times are GMT |
