![]() | Home > Off Topic - Other Cars > Discovery 5 not 4 ( sorry ) |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1083 ![]() ![]() ![]() |
Should be the same as a RRS, so a small rocker switch on the panel below the gear selector dial, drivers side I think. The opposite switch is the suspension raise/lower |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
@Andy s , thanks for the prompt reply , when sitting in the drivers seat there is a panel in front of the gear selector which has four terrain modes on top and then the lower / higher rocker switch with hill desent and the Eco button for the start stop but no switch for low range that I could see. I'm not sure of the spec hence why I wondered if they all had low range . 2015 4.4 AB
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Yep they all do have low range, at least I’ve never heard of one without....
Hi Northern Monkey, not a stupid question at all , its a 2016 so I assumed d4 but just spoke with him and its a D5 , my apologies to all who have read this . 2015 4.4 AB
Its what I call the older shape so I thought it was a D4, thats my excuse and I'm sticking to it. |
Thanks to Northern monkey a good search has revealed that low range was an option on D5s , if this is correct could that explain the loss communication fault code ?? 2015 4.4 AB
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 545 ![]() ![]() ![]() |
There's a D5 area on the D3 / D4 forum. You could ask there? 2016 Skoda Octavia VRS Estate
Thanks MikeO |
Thanks to all that answered, apparently D5 have optional low range |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Dolph34, officially you are a |
Apologies again , no more questions for atleast a month and definitely none unless they relate to my FFRR . Its amazing I can find my way to work |
Good man |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
They don’t - from 2014 they could come with a single-speed transfer box and a Torsen centre diff. |
