Home > Technical (L322) > Heated steering wheel problem !!
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
I know its getting warmer unlike this morning but does anyone have an idea what could be wrong with my heated steering wheel !! when i press the button the red light now only comes on for a split second then goes out and obviously the steering wheel does not heat up !! Censored Twisted Evil
Post #57211 28th Mar 2011 8:36pm
found this via the search, seems you need to strip and inspect
http://www.fullfatrr.com/forum/topic3750.h...ring+wheel ... - .- -.
Post #57215 28th Mar 2011 8:45pm
daveo
sounds like there is a short in the element or the module under the air bag is faulty V8 facelift Range Rover Autobiography 22" wheels.
Post #57217 28th Mar 2011 8:51pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
i can almost 100% say that it will be the actual heating element in the wheel that is faulty, i had the exact same problem and the only way to fix it was to replace the steering wheel with a new one, soon as i did that the heating function worked straight away.
Matt
Post #57240 28th Mar 2011 10:52pm
Jsb
I have a working wheel, removed from my 2007. Let me know if you are interested in it.
Post #57249 28th Mar 2011 11:19pm
bogie
Matt
same here - thats how I fixed mine - on exchange £100 ish from powerfulUK cheers
bogie
Post #59097 6th Apr 2011 7:01pm
