Home > Maintenance & Mods (L322) > Egr delete problem
Ianb4310
Egr delete problem
I’ve just fitted the egr from jgs4x4 to my 2006 td6 but I can’t for the life of me get the jubilee clip with “V” shape clamp from the stainless steel pipe on the left to seal against the solid blank on the bypass!! Anyone else had this problem
Post #572810 14th Nov 2020 6:46pm
Ianb4310
No one had any similar problem
Post #572921 15th Nov 2020 6:01pm
ur20v
A Trap
Some Photos might help
Post #572923 15th Nov 2020 6:13pm
Ianb4310
This is the one I’ve fitted, where the part circled in red joins the stainless steal cooler pipe I cannot get a good seal
Post #572928 15th Nov 2020 6:23pm
Ianb4310
This is the joint circled in red I can’t get it to seal properly
Post #572930 15th Nov 2020 6:28pm
DomenicoSpano
Belgium 2004 Range Rover Vogue Td6 Java Black
You need to fully open them (like fully non attached anymore) and then reattach it
Post #573034 16th Nov 2020 7:30pm
DomenicoSpano
but then again the question stays.
Why not remove the whole thing? cooler and all
so i'm now going to do the last as well.
Reason?
Egr cool thermostat can give issues so beter gut the full thing
Post #573035 16th Nov 2020 7:31pm
Ianb4310
How do you do that?
Post #573036 16th Nov 2020 7:33pm
DomenicoSpano
Do what ?
fully open the spanner?
Keep turning
google
-fully remove egr
-remove egr cooler td6 and you will find.
Don't want to post links
on ebay there is the egr-delete seller who has the complete set
but don't want to adv anybody but it could help
Post #573037 16th Nov 2020 7:41pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
The reason not to remove it is an obvious EGR or DPF delete/bypass is an MOT failure in the UK.
How strictly this is enforced is down to the MOT tester but if you want make sure you pass then don't make obvious changes like removing it completely.
Quote:
8.2.2.1. Exhaust emission control equipment
You only need to check components that are visible and identifiable, such as diesel oxidation catalysts, diesel particulate filters, exhaust gas recirculation valves and selective catalytic reduction valves.
If a diesel particulate filter has clearly been cut open and rewelded, you should reject it unless the vehicle presenter can show evidence that there was a valid reason to cut it open, such as for filter cleaning.
    Defect--------------------------------------------------------------------------------------------------------------------Category
    (a) Emission control equipment fitted by the manufacturer missing, obviously modified or obviously defective---Major
    (b) An induction or exhaust leak that could affect emissions levels---------------------------------------------------Major
    (c) Evidence that the diesel particulate filter has been tampered with------------------------------------------------Major
Post #573086 16th Nov 2020 10:31pm
Ianb4310
The clamp was broken but must have overtightened it ! Ordered a new one off the bay and fitted sealed up nicely thanks
Post #573340 18th Nov 2020 5:47pm
