Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4
Page 4 of 7 <1234567>
GreyPaint
United Kingdom 2012 Range Rover Westminster 4.4 V8 Alaska White
I did mine’s yesterday - battery went all of a sudden and Halfords who I booked to do the work, refused to touch it!
Anyway, found this and many thanks to OP for the help - it was easy, apart from the special tool needed for the two bots...
So, I used a 1/4” socket set and knuckle and took out the 10mm nut holding the electronics and was able to lift the unit out, after disconnecting the top connector.
Getting it back in, I used a little sausage of blue-tac to hold the nut in the socket until it was engaged on the thread....
Post #568512 1st Oct 2020 4:16pm
ffaffage
Had to do mine recently, this thread definitely helped, thanks all!
I put in an Exide AGM from Tayna (my goto battery supplier - always well priced, and fast delivery), I'm surprised at how small the batteries are on these beasts, and also how awkward they make it to get to them! Couldn't have been made harder if they'd tried.
A very straightforward job though, just more disassembly than you'd expect,and without this guide I'd have been stuck not having the right security bit to hand to do the ECU. That would have meant taking another few days to get it done.
The new battery programming was easy enough in IID, and the FBH heater works. Better than that, the car now starts without jumping if it's been left for more than a day Very Happy I remain amazed at what my portable pocket sized LiPo jump pack can start. It gets a bit warm with an old Defender diesel that is a poor starter, but didn't even break a sweat on my 4.4. TDV8.
Post #570200 18th Oct 2020 10:22am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
can i ask why people are fitting AGM batteries to there 2012 TDV8 4.4?
unless i have missed something they are not start stop cars?
my 2012 car still has the original battery on it and it is not a AGM battery am i missing a trick?
Post #571863 4th Nov 2020 5:34pm
DrRob
AGM were fitted by dealers following a lot of issues with non AGM original fit batteries. Most of us are now on AGM. Just replace yours with AGM when the time comes Thumbs Up
Stop start is a red herring in this case Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #571868 4th Nov 2020 6:12pm
Jayk69
good to know thanks for that Thumbs Up
i would have gone for the cheaper option!!! Laughing
Post #571880 4th Nov 2020 8:25pm
mjdronfield
I always thought they had AGM from new. Shows what I know 🀣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #571882 4th Nov 2020 8:31pm
GGDR
so my 2011 4.4TDV8 currently has a 95aH / 850 (branded JLR with a small Varta Logo) battery which needs replacement.
Speaking to a main dealer parts guy, he is offering a 90Ah / 850.
Being from. main dealer it is branded JLR, this one with a small Exide Logo.
I have queried that it is 5A less but he has put my VIN in and he says the 90Ah / 850 is correct.
It's coded GX73-10655-BC
He even showed me a 4.4SDV8's battery in-situ on a 2019 and it is indeed 90Ah / 850.
Thoughts?
. Cheers, Greg
Post #573026 16th Nov 2020 6:44pm
Greg, back in 2018 i bought a proper LR battery with a part code of T4A 14085.... pretty sure it was 850 ah... ... - .- -.
click link for ,
FORUM WIKI
HOW TO ΖŽκ“•βˆ€κ“•Oκ“€ PICS
Post #573029 16th Nov 2020 7:04pm
GGDR
thx Stan, do you remember was it 90 or 95ah ?
. Cheers, Greg
Post #573030 16th Nov 2020 7:10pm
i just googled that part number and it came up with 95ah.. ... - .- -.
click link for ,
FORUM WIKI
Post #573031 16th Nov 2020 7:12pm
GGDR
thx Stan Thumbs Up Cheers, Greg
Post #573057 16th Nov 2020 9:12pm
Baltic Blue
Greg,
I changed mine a couple of years ago for this one....
2 reasons...
It was the cheapest with free next day delivery to your door.
It comes with a 5 year Warranty.
It is 95 Ah.
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #573059 16th Nov 2020 9:19pm
Clabs
Greg - I queried the same with Dan when I ordered my new battery from Duckworths and received the 90AH Excide product code GX73-10655-BC.
Dan's response was that this was the new revised replacement.
Cheers, Mark Current Cars:
MY11 5.0 SC Stornoway - sold
MY06 TD6 Zambezi - sold
1997 BMW E36 M3 Evolution Convertible Estoril
Post #573061 16th Nov 2020 9:27pm
GGDR
Amazing thanks Mike and Mark
. Cheers, Greg
Post #573067 16th Nov 2020 9:48pm
GGDR
Quote:
Remove this plate by undoing the two 5 point Torx Security Screws. (You probably won't have a tool for this, but they are available on Ebay.)
does anyone know the size (or a link) to the correct 5-point Torx Security Screws for the ECU ?
Cheers,
. Cheers, Greg
Post #573733 22nd Nov 2020 1:33pm
