Home > Technical (L322) > metallic rattle for driver's side of engine bay - thoughts
scene247
I noticed yesterday that when the engine was idling and I got out there was a metallic rattle coming for the engine. Sounds like some kind of heat shield or something that might have worked loose?
Before I take it in just wondering if anyone has any thoughts about what it could be as might be simple fix?
Thanks.
Post #57050 28th Mar 2011 9:13am
what year/petrol/diesel ?... ... - .- -.
Post #57051 28th Mar 2011 9:15am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
It's a TD6 - they all sound like that Laughing
Post #57054 28th Mar 2011 9:34am
dan_uk_1984
Without having your car in front of us it's kinda difficult to diagnose an odd sound...
Could it be a heat shield or something has worked loose?
Sheep
Post #57057 28th Mar 2011 9:44am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Two possibilities spring to mind.
Heat sheild over the exhaust manifold.. needs the air box to be removed to get in to it.. which needs the inlet manifold removal.
More likely though is the dust sheild on the back of the brakes rattling on tickover... you can give this a wiggle / poke through the wheel to check. If it is this the guard gets fatigue around the bolt and snaps. It is possibel to cunningly remove the bolt and slide a large washer in then refit without having to pull off the wheel / disc and caliper.
Many other things but those are the first too that spring to mind. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #57058 28th Mar 2011 9:58am
scene247
Thanks guys.
Is a TDV8 MY2011, done 4,200 miles. Understand it could be many things and difficult without actually being there hearing it. I only heard it yesterday (but then not often out of the car with engine running.
Hmm, interesting on the brake cover - I did clean the wheels on Saturday and poking the brush through was quite tight as got Brembos on 19" wheels so not a big gap. Might have possibly knocked this and it's now rattling.
Just a bit annoying on new car to have rattle like that. If all else fails will just head to dealer and get them to sort it. Thumbs Up
Cheers guys.
Post #57060 28th Mar 2011 10:42am
pretlove
i had this problem yesturday and when i looked it was the dust shield on the front drivers brake had come loose Thumbs Up i did what elpeede says you should do "RANGEISM WILL NOT BE TOLERATED"
Post #57061 28th Mar 2011 10:43am
scene247
Fingers crossed it's the brake disc cover, seems like it could be the most likely thing. I will check tonight when I get home, when it will still be light I hope (the good thing with the clocks going forward!) Very Happy
Post #57071 28th Mar 2011 11:28am
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I had to do my nearside disc cover last night.............all quiet now Thumbs Up
Post #57279 29th Mar 2011 11:00am
scene247
All seems ok now. Started the car and seemed ok. Did give the brake cover a little prod too. Very Happy
Post #57334 29th Mar 2011 5:16pm
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Hi , I had exactly the same noise , rattling on idle and also after you blip the throttle on run down.
I checked all the heat shields and in the end it was the front catalytic convertor.
£300 later for a new cat and all is well CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #57336 29th Mar 2011 5:19pm
