Home > Maintenance & Mods (L322) > Parking sensors AGAIN - Instructions for rear replacing
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Hi Guys,
I know this topic has been covered alot of times but i cant find a definative "how to guide" to replace the rear sensors - there has been some nice pictorial explanations for the front replacing but not the rear.
Is it necessary to remove the rear bumper plastics? or is there anyway to remove the sensor and replace with the bumper in place? (without the need for specialist Stealer tools)
Ive got a replacement sensor to do (albeit the actual inner sensor head is an oblong shape instead of round) but im assured it is for a 2006+ FFRR.
Lastly , the sensor needs to be colour coded - any do's or dont's as to paint / laquer e.t.c.?
Thanks Muchly CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #57331 29th Mar 2011 5:05pm
this is from rave and it appears that the sensor goes into a holder of some kind.. ... - .- -.
Post #57332 29th Mar 2011 5:11pm
Vogue Owner
It looks the sensor holders have a moulded snap clip which means it probably won't come out without getting behind it. CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #57335 29th Mar 2011 5:17pm
you might be lucky and be able to get your hand behind to release the clips. ... - .- -.
Post #57337 29th Mar 2011 5:23pm
Vogue Owner
I've had a look and there seems to be a black plastic lower boxed trim which unless you have hands like a child instead is impossible to get into CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #57340 29th Mar 2011 5:31pm
just a thought, one of my sensors wasnt working and it was the wiring that was chaffed and not a faulty sensor..is it defo that your sensor is faulty..
btw you can get to the wiring easier.. ... - .- -.
Post #57342 29th Mar 2011 5:34pm
Vogue Owner
Not sure.... The sensor (passenger side rear) is not clicking , I thought the chaffed wiring usually occurred on the drivers side? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #57344 29th Mar 2011 5:40pm
mine was on the off side, but might be worth a look to see if it is the wiring.. ... - .- -.
Post #57346 29th Mar 2011 5:42pm
Vogue Owner
Mind you , the will be the 4th sensor replaced in 2 years , the last 3 done under warranty CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #57352 29th Mar 2011 5:58pm
do you pressure wash yours much, could be water causing them to fail.. ... - .- -.
Post #57353 29th Mar 2011 6:04pm
Vogue Owner
Yep many times , I suppose that could be the cause - crap quality then , they should be IP rated! CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : BMW M3
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #57355 29th Mar 2011 6:11pm
Laughing .. ... - .- -.
Post #57356 29th Mar 2011 6:17pm
stu
hi everyone, i thought this was as good a place as any to post my question. i have just picked my car up yesterday and spent ages reading through the owners manuals... Shocked
my button on the dash flashes and gives of a long tone, which if i have things right means there is a fault.
is there any easy way of finding out what the fault is?
thanks stu Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #63053 8th May 2011 6:22pm
yes there is stu, switch on the ignition without turning the engine over , then stick the range into reverse..go round and listen to each sensor , it should make a 'clicking' noise...if a particular sensor doesn't then its the one that's faulty or the sensor wiring is .. ... - .- -.
Post #63060 8th May 2011 7:20pm
stu
hi, thanks for the reply.
does this check go for the front sensors too? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #63062 8th May 2011 7:26pm
