![]() | Home > In Car Electronics (L322) > 2010MY Camera specs? Interchangeability with L405 spec? |
| Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 355
I've a broken lens on the front left camera on my 2011 (2010MY) L322.
Replying to my own thread, second sign of madness?
| JNC Member Since: 23 Feb 2020 Location: UK Posts: 293
I suspect they use the same/similar camera system.
Yup, that’s what I thought - I’m also wondering if the lens portion itself is easy to swap. There’s an M12 thread used on many small CCTV or board cameras which I think might be a cheap way of replacing the lens when it gets stone chipped.
Camera appears to be analogue with the signal transmitted using LVDS.
Yeah, they seem to be used on RRS's from memory, but still very expensive - I'm guessing all the cost is in the shape of the housing (as in they didn't use it for long and so it's more expensive), which is my logic for pursuing a retrofit of the later type cameras which are much cheaper.
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2723
There’s a recent vid from powerful uk on this subject, worth a look |
Thanks for the tip! I found this one on the reverse camera.
| All times are GMT |
