Home > Technical (L322) > Does it sound like the turbo/turbos have gone
Ranger22
Scotland 2008 Range Rover Vogue TDV8 Adriatic Blue
2008 Vogue 3.6TDV8
No power, very smokey on start up, oil in the inter cooler pipes
Opinions please
Post #573651 21st Nov 2020 2:15pm
DrRob
Take it to Mike Park at MMP in Dundee... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #573658 21st Nov 2020 3:29pm
ur20v
A Trap
Oil in intercooler and pipes/hoses is normal so doesn’t always follow the turbos are gone.
Black smoke might be fueling. If you have a boost leak.
Blue smoke might mean turbos
Post #573662 21st Nov 2020 3:39pm
Ranger22
Where the fun in that Very Happy
Post #573667 21st Nov 2020 4:04pm
As usual, check the top hoses and manifolds for a boost leak, especially the top right hose.
If it’s there all the time it’s probably something else tho. A boost leak fault tends to reset and then re occur when you give it a boot full.
Could be stuck EGR valves. Which can be read with a diagnostic. There is nothing that can't be fixed with a hammer😜😜
M3 3.2 EVO Convertible Techno Violet
Post #573683 21st Nov 2020 5:52pm
Ranger22
Loss of power is there constantly. Will check hoses too
Post #573685 21st Nov 2020 6:16pm
Ranger22
These are codes from the RR, any thoughts?
Post #573958 24th Nov 2020 7:34pm
