Home > In Car Electronics (L322) > single/dual view monitor
Landmark
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Hi all the original thread sais fact known with a brilliant write up. Problem is I have a 2010 fitted with the latest looking single view however wanted dual so I went out and brought dual view screen however they look identical except mode button sais dvd and audio button has legend showing two screens. Problem is this dual screen has part number on rear stating its a DNNS035 not 036. Any advice
Post #573794 23rd Nov 2020 10:48am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
My 2011 car also has a DNNS035 and has the word "DVD" on the enter button, despite it not being the DVD nav version (it has the hard drive).
You can have a HD based NAV but still have a DVD player for audio/video, my car doesn't have the DVD fitted, but it still has the markings on the head unit button Smile
I should also say, my car is a German market vehicle and it's stamped "EU" on the label on the back, the actual Land Rover part as far as I understand is: bh42-10e887-rc
Post #573800 23rd Nov 2020 11:42am
mjdronfield
I’m not sure this helps any, but mine does have Dual View, and it looks like this....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #573802 23rd Nov 2020 12:02pm
Siftah
Yup, my undestanding is that "1 2" image on the Audio/Video button is only there on the dual view units. So if you have that, you have dual view.
The "DVD Enter" text is there on all units, regardless of whether you have the DVD nav or not and regardless of whether your actual vehicle is fitted with a DVD player for playing back DVD's (ie: as opposed to a DVD player used for Navigation data).
And I think as the thread mentions, only the 2010 model year had the HD based nav fitted, previous to that it was DVD based.
Dual view only came in on the 2010 model year also, but obviously this wasn't fitted to all 2010+ cars, it was an optional extra.
Post #573807 23rd Nov 2020 1:01pm
Landmark
So mine being a 2009 but with digital dash and non BMW looms. The main dealer said it was a 2010 spec probably pre registered. My head unit looks just like the one in the picture but it doesn't have the dual screen logo and the button that sais dvd on mine sais mode. So the question is I have now brought dual view one, will it work or are there additional hardware I need to get. I do have an iid tool so this might help if reprogramming is required.
Post #573983 24th Nov 2020 10:18pm
darrenm
Mine is a 59 reg and has the dual view
Post #573988 24th Nov 2020 10:46pm
Siftah
Have not done a swap of this "TSD" (Touch Screen Display) as it's referred to in the workshop manual so I'm afraid I can't confirm! Sad
It'll definitely need to be coded in as I believe from reading the workshop manual all the various parts of the audio system have codes and are needing to be in sync.
I would imagine you'll be able to swap it and just re-code it without any problems, the connectors should all be the same as it's just a different screen, all the audio/video goes via the MOST bus which will be the same connector (ie: it's not like there's two connectors because it has "2" screens, it's all done via one MOST loop).
Certainly appears from googling that the rear of the two versions of the screen are the same too, so I think you're good to go... Thumbs Up
Post #573995 24th Nov 2020 11:04pm
Landmark
Thanks everyone I will give a go soon and report back.
Post #574118 25th Nov 2020 9:42pm
Mike220
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Looking forward to seeing how you get on, interesting little project 2011 Vogue SE Tdv8 FFRR
Post #574123 25th Nov 2020 9:58pm
Landmark
Mmm should be and if it all works then I would like to have a go at making it do android. Got a mate who is a avionics engineer and he is off work at the mo and said he would help me convert if I source parts.
Post #574237 26th Nov 2020 9:44pm
Siftah
Making it do Android, as in, converting the TSD for one that runs Android would be a large undertaking - there's not really any support for MOST within Android, nor the capability for Android to replicate many of the functions that the TSD does within the infotainment system.
You'd be best reading through the workshop manuals on the Infotainment section to get an idea of the setup Smile
The only kits out there which integrate with the in-car stuff do it by basically intercepting the CAN bus, reading the button press for the hangup button and then intercepting the LVDS connection to the screen and hi-jacking the output from the touch-screen display.
Systems like Naviplus do this, you solder into (or use bypass cables/ribbons now) to intercept the CAN bus, LVDS for the screen and the touch screen cable to grab the key presses. It's a significant amount of installation effort, but it does leave you with a very nice integration which also leaves the cars native functionality untouched.
Much easier than replacing the entire head unit or TSD! Smile
Post #574251 27th Nov 2020 2:19am
Landmark
How much are the parts for naviplus set up. Do you know.
Post #574263 27th Nov 2020 10:22am
mjdronfield
Some fitting info here....
https://www.fullfatrr.com/forum/topic56823...t=naviplus
https://www.fullfatrr.com/forum/topic56194...t=naviplus
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #574265 27th Nov 2020 10:29am
Landmark
Just been on there website and they want £650 for kit parts., or at least I think that's the price. Is that correct. Or is that for kit and install voucher.
Post #574268 27th Nov 2020 10:38am
mjdronfield
Pretty sure that’s just the kit. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #574278 27th Nov 2020 11:16am
