![]() | Home > Maintenance & Mods (L322) > Parasitic Battery drain culprits |
| Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 355
Haven't got the fuse references to hand, but I believe the usual suspects include;
| coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
That looks like a very useful device! Thanks for sharing 1995 4.6 v8, green/tan (long gone)
| Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182
Thanks for the info, I'm gonna get one, seems really usefull |
| NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 125
I once had a constant drain which was finally tracked down to corrosion inside the tow sockets. |
Wow! Who would have thought to consider those? Not me for sure, thanks for the heads up. 👍 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
| Ian G Member Since: 07 Sep 2020 Location: Liverpool Posts: 35
I had FSR failure on mine but not such a mystery to diagnose, it was making so much noise the neighbour knocked to say it was keeping him awake. |
I didn't get around to checking over the weekend, but I just walked past the car this evening and notice the screen (drivers info screen) was on!
As an update, sort of found what's causing my 0.2amp drain, details in this thread: https://www.fullfatrr.com/forum/topic57611.html |
| D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 575
What a great idea, just gone on my wishlist! Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Yeah, have a look at this model too, it does the small "mini blade fuse" that you get in the later fuseboxes!
If you place a stamp sized piece of tissue paper over the little grill containing a tiny fan for the HVAC you should find it is held in place by the suction of the fan, when your turn off the engine and lock the car, after approx 15 mins the tissue should fall off indicating the fan has, shut down therefore no suction, if it remains in place then its likely the fan is, still running albeit silently and drawing current.. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I went with the current meter, luckily, as the drain comes back after a few hours so the tissue probably wouldn't have helped! |
| All times are GMT |
