Home > Maintenance & Mods (L322) > Bonnet/Hood Service Position
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Hi everyone,
I've looked through the owners manual and the service manuals but can't find the section that shows how to open the bonnet ("hood" for those of us across the Atlantic!) to the service position! There are a number of places that instruct you to do so but I can't find any section that actually tells how!
Is this one bit of important information hiding in plain sight or is this something that's just assumed everyone knows?
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #574082 25th Nov 2020 5:26pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
First of all, you need 2 folk.
Standing at either side , flat screwdriver , where the bonnet struts attach to the car, pry the small metal collars out from the base of the struts , keep your hand over them as they can easily ping away. Remove from mounting hole, leave hanging from bonnet. Do same other side.
Then push the bonnet vertical, and look at the hinge. There is a metal plate which you need to pull, and push into a receiving hole, it’s quite obvious when you see it. Do this both sides and it will keep the bonnet vertical.
DO NOT DO ON YOUR OWN, I DID, AND THE BONNET SHUT ON MY HAND FROM A GREAT HEIGHT. NOT PLEASANT.
Post #574083 25th Nov 2020 5:37pm
lschwarcz
I guess this confirms that it's not documented in the service manuals!
Thanks for the directions!
Bournville/Ivory
Post #574086 25th Nov 2020 5:43pm
Baltic Blue
You can easily do it single handed if you have a suitable prop to hand ready to hold it vertical. I have used a brush in the past, but today just happened to have “Stan’s 4x2” to hand.
Post #574090 25th Nov 2020 5:57pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Don't attempt in a stiff breeze. Bonnet acts like a sail in the vertical position. Easy enough to do single handed, just have your wits about you! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #574115 25th Nov 2020 8:25pm
DrRob
Can be done single handed but only with "experience" from doing it first with a helper (SWMBO Whistle ) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #574159 26th Nov 2020 9:39am
p38arover
Australia
I’m pretty sure it was in the P38A workshop manual - that’s how i found out about it. When i got the L322, I noticed it used the same method. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #574168 26th Nov 2020 10:32am
paul70
some good pictures on the changing battery Wiki
https://www.fullfatrr.com/forum/topic43662.html
Post #574174 26th Nov 2020 10:52am
Woofster
Canada
The battery replacement YouTube video from Powerful UK pretty much walks you through it.
I've always put the bonnet/hood into service position by myself too. Unclip one strut. With my hand supporting the front edge of the bonnet/hood, I walk around to the other side. Unclip that strut. Tilt bonnet/hood up into service position. Lock the tab. Now, even though there's only one side that's locked in place, the bonnet/hood is almost upright so there really isn't much of a moment/torque acting about that hinge. Just walk over to the first side again and lock that tab in place.
Of course, I only ever do this in my garage so I never have to worry about wind, which is definitely something to consider if doing this by yourself. 2010 RR SC
2007 RR SC
Post #574254 27th Nov 2020 3:00am
