Home > Maintenance & Mods (L322) > 3.6TDV8 mods? |
lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59 |
Hi Ricardo, I "might" be buying an identical SE to you. Mine is a 2009 140k, new turbos, gearbox service, fsh negotioned £7400 but not much mot left. I see it next week to make a final decision, will find out about egrs and maps then. I keep getting told that the 4.4 is a lot better but this is a lot cheaper and as it will do lots of short trips no DPF! |
25th Nov 2020 10:55pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
Turbo drain is specific to 4.4 not 3.6.
25th Nov 2020 11:14pm |
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 |
Yes I've looked at 4.4's but can't find one in great nick and reasonable mileage for the money. One I am looking at has only done 83k and has a full detailed service history. When were dpf's fitted from its reg date is 29/9/09? How much doe EGR removal cost roughly and what's involved? |
26th Nov 2020 1:22am |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 179 |
You will not find many 3.6s with dpfs I have only ever seen one which was a German vehicle |
26th Nov 2020 2:00am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
I didn’t remove my egr’s or map them out, I used the blanking plates, easy job and stops egr valve fragments going through the engine... another benefit is the oil is cleaner (less carbon/exhaust products getting in the oil) 👍
26th Nov 2020 8:46am |
A 4.4 with its known issues won’t end up needing a new engine.
26th Nov 2020 10:03am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
I mapped them out when I did it but subsequently read a few posts from people reporting that they didn't bother and didn't get an EML. Mapping them is belt and braces but if you have an IID tool you could try blanking and then only buy + apply the patch if you run into problems (thereby potentially saving £200ish). 2016 Skoda Octavia VRS Estate
26th Nov 2020 10:32am |
Good plan.
26th Nov 2020 10:34am |
Thanks some good info and advice, bit clearer now. The one I'm looking at has new alternator, just had over £3k spent on it at Land Rover, Had phone/TV modules replaced as some water got in apparently. I've asked for gearbox flush and filter change as part of the deal which will be done. Sounds like blanking the EGR,s is a good move, is this a DIY job? I'm reasonable mechanically but no expert! Can it be done and then remapped by someone who can do it after? |
26th Nov 2020 11:19am |
If you are talking 3.6.. the egr blanks are an easy job, about 40 minutes taking your time, no special tools. Theres some detailed posts on this forum.
26th Nov 2020 4:13pm |
Yes it is a 3.6. Will check threads out and see if it's ok for me to do! Thanks. |
26th Nov 2020 8:13pm |
