![]() | Home > Technical (L322) > Need new Alternator |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
That’s ridiculously expensive for an alternator replacement - doesn’t matter what ff model you have.
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
Looks like the ex Landrover guy is looking to charge you main stealer prices plus a generous tip on top |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
That does sound rather expensive, They’re not the easiest job in the world, especially if your not a mechanic, but I would expect somewhere circa half the price you were quoted from a good Indy. If he’s an ex LR mechanic, the manual does suggest removing the turbo to gain access on the 3.6, a horrible task in itself, but they can be done by taking various pipe work off around the front of the engine instead and they will wiggle out through the front, there’s a good how to in the wiki.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
I had ours done at an good ex BMW garage in Cambrdgeshire. Charged book time at 4 hours labour, can't find receipt, but IIRC was about £85/hr. Oh, and it took them 6 |
flexfly Member Since: 24 May 2017 Location: Hampshire Posts: 16 ![]() ![]() ![]() |
Had mine replaced (4.4tdv8) in March for £625 parts and labour.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
I've been "lucky" enough to have done mine twice (first replacement seized), There is a good write up that I contributed to, so try and follow that and it shouldn't be too bad. It's just a shame it didn't fail in the summer, as it can get a bit chilly working outside in this weather.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1582 ![]() ![]() |
Mine (BMW M62 4.4V8) failed last year. List price for the alternator (aftermarket, not through a dealer) was a little over A$3,000.
A$3,000 = £1600 |
Yep. Ron B. VK2OTC
