Home > Maintenance & Mods (L322) > Cooling Fan Wobble
Sonearly
Cooling Fan Wobble
Advice please
In the process of changing belts and pulleys due to the pesky canaries and morning squeal. Really didn’t realise how worn the belt was until I compared against the new one. But I have a question that I would be grateful if other TDV8 4.4 owners could confirm. The cooling fan has a noticeable wobble, the clutch is nice and tight on its spindle and has no play. When on idle the outer plastic rim has a visual wobble, with the engine off turning the rim shows about 5 mm movement from true when rotating . Is this to be expected of a plastic fitment of this diameter ? There is no vibration on idle just a visible movement / shimmer. I know it’s chilly out there but if someone could check theirs it will save a substantial unwanted cost.
Your help and feedback grateful accepted, hopefully normal or wife’s Xmas present from Lidl rather than John Lewis.
Post #574245 26th Nov 2020 11:43pm
kevinp
Just had a look at mine mate. I spun it by hand and there is about 3mm of deviation between the end of the blades.
Post #574270 27th Nov 2020 10:47am
Sonearly
Very grateful for that. Much appreciated.
Post #574275 27th Nov 2020 11:14am
