![]() | Home > Maintenance & Mods (L322) > M62 PCV and oil separator parts |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 165 ![]() ![]() ![]() |
Argh. What a pain in the bum this is turning out to be.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
HW1 and HB1 aren't part nos. I assume you are looking at Microcat. Click on HW1 or HB1 and it will take you to the part no. And description below the diagram.
Thanks P38.
on reflection, i wonder if these copper sealing washers are just the same as the oil drain plug washer. part number ETC7398, which seem pretty standard. 2010 L322 Autobiography Black Edition
You are right Knares.
oh, and upon copper washer inspection, its the same size as the sump plug. 2010 L322 Autobiography Black Edition
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 821 ![]() ![]() ![]() |
you are lucky with the smaller pipe, min was all soggy and broken in several parts
The small pipe connects to the bottom of the cyclone, the larger pipe goes to hose connected the drain on the PCV valve. No need to remove the inlet manifold. Connecting the smaller hose may have been easier without the inlet manifold in place but I didn't do it that way. I didn't replace the copper washers (HW1) in the diagram. I reused them. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
yes, you are right
if you buy 6C342A
Im still on the project - I double checked the smaller pipe and all is o.k and got some more copper washers now so all good for the banjo bolt etc.
thanks
