![]() | Home > Maintenance & Mods (L322) > Removal of rear Wiper/washer Motor: How To with Pics |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Gotcha! Thanks |
Jimnic007 Member Since: 13 Aug 2019 Location: Cheshire Posts: 77 ![]() ![]() ![]() |
Hi,
Me again! Sorry
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
Jim,
TomP Member Since: 06 Jan 2021 Location: Surrey Posts: 10 ![]() ![]() ![]() |
Rear Wiper has just started to play up. Washer fluid on the rear parcel shelf. Cleaned up nicely with carpet shampoo. Also noticed that the rear wiper blade failing to make contact with rear window. Started to investigate today. Trim covering the wiper unit came away with gentle pulling. Found that the washer fluid feed pipe had separated from the unit where it connects to the wiper unit spindle. Reconnected and tested for fluid and wiper operation - nothing. Should I start with the fuse or, assuming the unit is clogged and jammed at the spindle, remove the unit for de-gunging and lubrication. Any thoughts or advice welcome. Having read the experience of fellow RR travellers to date, I have some foreboding as to what lies ahead ! |
Hitby Member Since: 20 Oct 2017 Location: Middlesbrough Posts: 47 ![]() ![]() ![]() |
Sorry for reviving an old thread.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Mine stopped working so I stripped it down and found it full of brown sludge. Cleaned it all out and filled it with lithium grease and it still doesn’t work. However I am getting an error message on IID tool saying it’s not parked so I think I might’ve put it back together wrong. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Thanks, yeah, I think I reassembled it correctly, all the mechanical cogs move freely but the fact it's clicking and not turning makes me think that the motor itself has seized 👎🏻 |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
Super helpful post again, thanks to everyone for the images and tips.
Mikeerhymes Member Since: 01 Sep 2018 Location: Manchester Posts: 29 ![]() ![]() ![]() |
Has anyone tried this on a MY11 before I start stripping it down? I have the internal leak out of the motor shaft.
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
I have. Same basic assembly but the electrical connections are somewhat different. I drilled out the shaft to 6.5mm and fitted a hose through it directly to the factory jet connection. Copes fine with the amount of movement. I was going to use a new seal but the shaft was too worn to seal. |
