Home > Off Topic > Scissor lift |
Super7 Member Since: 23 Feb 2019 Location: Somerset Posts: 19 |
Considering the same, will be interested in anyone's experiences with these and a FF. Current 5.0 S/C Autobiography LPG
29th Nov 2020 11:31pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Your garage extension isn’t going to be big enough. 3m is only just wide enough to open each door about 1/2 way when the Range Rover is centralized. There will not be much room to work on the sides. 8m length is plenty and still have room for a bench and or tool chest.
30th Nov 2020 11:02am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3677 |
V8 Bob,
30th Nov 2020 11:12am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 896 |
Surely you mean you moved to a new garage with a house attached Mike?
30th Nov 2020 12:09pm |
My garage....her house.
30th Nov 2020 12:13pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 343 |
Appreciate constraints width wise but ideally fact most scissor lifts are portable I can position one to use added width of connection to existing garage. The existing garage is much wider at 5m with a ceiling height of 2.6 m so lift could be used in there as well.
30th Nov 2020 8:51pm |
Ok, and yes. On the lighter SWL ramps like ~2.5 and 3 tonne which can lift the Range Rover it’s scary. Very wobbly if you are pushing and pulling on anything, this goes for scissor and two post lifts. Just feels like the car will fall off at any moment especially the scissor lifts that are mobile and not fixed to the ground.
1st Dec 2020 10:22am |
Thanks for that. Lifting a Range River wouldn’t be main use although would be nice to be able to have something to provide a safe and steady lift to do brakes etc. Main use would be a project car as yet undecided on whether to scratch a long time itch to build a lotus 7 type car or to build a car for auto tests.
1st Dec 2020 2:56pm |
For a kit car build a portable scissor lift would be ideal especially for a lotus 7 type like Westfield or Caterham etc, they are flat underneath and everything runs inside or down the sides so would work well for building and maintenance this type of car.
1st Dec 2020 5:11pm |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 324 |
I,ve just bought a quickjack lift(genesisequipment.com.au) for my rangie,as I dont have the firm(cement) floor( I have pavers as the sewege pipe runs underneath).
1st Dec 2020 9:48pm |
