Home > Technical (L405) > L405 suspension
Watty
Scotland 2017 Range Rover Autobiography SDV8 Santorini Black
L405 suspension
I have just purchased a L405 4.4 vogue autobiography, i also have a L322 vogue, i have found in the l405 that the vehicle wallows and floats quite a bit it is fitted with 22" wheels, i feel that the shockers on the rear are soft as my l322 does not do this . is it me or does the l405 drive like that.
any comments appreciated Rolling Eyes 07 Vogue SE Java Black 3.6 TDV8
Black Leather heated/ cooled seats
Piano black trim deployable side steps
L405 Autiobiography 2017
Santorini Black with black pack
13 L405 4.4 Autobiography
Post #574642 30th Nov 2020 4:32pm
knwatkins
I believe there was an issue with the oil leaking within the dampers on these vehicles. It could be worth searching for previous posts concerning this.
Coming from an L320 RRS, my L405 is 'floaty' when cruising on the motorway and I put this down to the softer suspension providing more of a cushioned ride than the Sport. However, throwing it around some bends on A roads, it firms up, corners flat and handles really well.
Not sure if this helps, but the suspension is supposed to be dynamic and change it's behaviour depending on how and where you are driving. If you are finding it consistently floaty at all times, you may have a problem. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #574694 30th Nov 2020 10:25pm
charlie croker mk2
Check the front track control arm bushes , can you twist the upper part even with the car on the ground . Do the same for the lower arm ( Wishbone ) bushes . You need the car jacked up for this .
Post #574695 30th Nov 2020 10:26pm
TJH1985
We had a 3.6TDV8 and a 4.4 Autobiography with 32k sat on the drive on 21” wheels for a while and I can’t say I thought it wallowed or was over floaty (for a RR) I actually thought they both drove exceptionally well just the L405 was if anything flatter and more controlled when pushing on, not that you ever do in a RR and was generally just quieter. My other half couldn’t tell any difference in ride quality which I thought was a testament to the L332. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #574709 30th Nov 2020 11:44pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I was surprised to see how "wallowy" the L405 (20") is compared to the L322 (19"). We went to Greece last summer with friends that drove an Audi Allroad (3.0 TDI) and although we could keep up with them in straight line, the RR didn't stand a chance in curves... The dynamic mode helps, but not much... I think I read somewhere an interview in which a JLR person declared that clients required a smoother ride...
Post #574722 1st Dec 2020 7:23am
322BLL
Estonia
If they(JLR) would also focus on autobahn and nürnburgring performance, it would not be one of the best go anywhere suv anymore. Smoothness and comfort over high speed and curves performance anytime.
Post #574724 1st Dec 2020 8:31am
adara
Just sayin' that the L322 was much less scarier in curves... And performed quite well on rough surfaces too...
Post #574732 1st Dec 2020 10:34am
Martin2
Doesn't help the OP, but the reduction in body roll is one of the reasons I went for the V8 over the V6 diesel. But even with the anti roll system it still has more float and vertical movement than I like on a twisty road, so I put it into Dynamic which helps and doesn't ruin the ride. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #574734 1st Dec 2020 10:49am
