![]() | Home > Technical (L322) > Heated Seats |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701 ![]() ![]() ![]() |
I believe the 'heated' seat set up differs slightly from the 'heated/cooled' set up, but this thread may well help you.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I take it you only have the heated seats (as opposed to the climate seats)? Do both front seats not work or is it just the driver's side? If one side works but the other doesn't then it sounds like the ecu is okay and either the back or base heater pad has broken. Don't know how easy it would be to check or replace them. Also there will be connectors for the heated pads under the seat which could be part of the problem.
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 ![]() ![]() ![]() |
Both seats act the same. I would have thought that a broken heater pad would only affect one seat? Was looking for a thread and couldn't find it so thank Fox.
You will be best off getting any fault codes read first. If you have a diagnostic tool, i.e. IID or similar, or can get access to one this should give you a good starter for ten.
lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59 ![]() ![]() ![]() |
My passenger seat seems to work on my new car, my driver is not blowing air. New peltor I suppose. Heated steering works a treat. 2009 TDV8 3.6 |
