Home > Maintenance & Mods (L322) > L322 3.6TDV8 Rear Brake Callipers Sticking
Tg87
Hi, I replaced my rear brake calipers last year when my near side starting sticking. I now have a off side starting to stick. Is this normal after just 12 months? Anything I can do to prevent this?
Post #573880 24th Nov 2020 9:41am
kevinp
Did you use copper grease when installing it. I know it's been used for years but you shouldn't use it on the caliper slides. Search for brake caliper grease and you'll find a set of three greases for different parts of the installation.
Post #573887 24th Nov 2020 11:13am
Tg87
Hmm I actually can’t remember if I used copper or a high temp grease. I think it may have been copper. Is this likely to do it?
Post #573892 24th Nov 2020 11:58am
kevinp
If you do use copper grease it really should only go on the back of the pads to help stop squealing. The slides usually have a rubber type grease. Copper grease is to sticky.
Post #573910 24th Nov 2020 2:11pm
Tg87
Rightio I’ll give them a clean off and start again this weekend. I think it may have actually been the parking brake. I’ve applied it and reapplied a few times and it seems to have sorted it. Just seems odd because the heat seemed to be coming from the outer of the disk not the hub. When I took the wheel off I could hear the shoes rubbing. It all turns freely now so fingers crossed!
Post #573921 24th Nov 2020 3:36pm
Tg87
Ok, did some investigation. Jacked it up and it sounded like the handbrake was dragging on the discs. I used the handbrake and centred the pads. It seemed to be fine. A week later it’s the same issue again.
Tomorrow I’m going to strip it all down remove the discs and give it all a clean re lube etc unless anyone has anything else I should be looking at?
Post #575196 5th Dec 2020 10:24pm
Make sure you take off and clean/wire brush/file back the rust off the caliper carriers where the pads sit in the anti rattle springs. This is important as the carriers can corrode and grip the pads, and aren’t normally changed along with the calipers.
Unless the pads slip into the stainless springs and move about easily then they will bind in the carrier and you will get overheating.
I use ceratec lube for the ears and back of the pads rather than copper grease. There is nothing that can't be fixed with a hammer😜😜
Post #575201 5th Dec 2020 11:05pm
D3Jon
Agreed - I definitely wouldn't put copper eaze on the caliper slide pins, I'd think it would degrade the rubber. I use red brake rubber grease if they need anything on the slide pins and ceramic brake grease on the back of the pads and where they contact the caliper. Having said that, there is strong evidence to say that modern pads with in-built shims don't need any brake grease on the back of them.
I've seen video's by professionals on YouTube where they recommend using copper eaze on the caliper slide pins - but would personally disagree with that, as I'm certain that "copper slip/ease/eaze/grease" is mineral based and just like oil or normal grease will degrade the rubbers with time that the slide pins fit snugly into.
Example at around 7mins (WRONG in my opinion) - https://rimmerbros.com/c/Replacing-the-rea...Rover-L322
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #575472 8th Dec 2020 12:42pm
D3Jon
I've had a rear brake backing plate corrode which has led to the shoe retaining pin falling into the drum of the rear handbrake causing a brake binding / scraping noise. You might want to make sure nothings got into the drum or anything has broken loose in addition to centering the brakes and re-adjusting.
Also drive slowly for 50 metres or so with the handbrake on to clear any corrosion build up that might have occured if you don't use the PB very much.
2014 Disco 4 HSE
Post #575474 8th Dec 2020 12:46pm
