![]() | Home > Technical (L322) > electrics not shutting down |
| BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296
hi folks
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432
FSR - Final Stage Resistor (hedgehog) ? .
hi joe,*
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721
It’s in the WIKI, top right of forum toolbar; https://www.fullfatrr.com/forum/topic781.h...eplacement |
ok i will take a look, thanks.
| Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351
According to this article, nope, if you're having the symptom of the fan staying on after the cars locked it seems a likely culprit.
hi there, well im not able to get down and the work as my joints wont allow so i need to arrange a garage to look at it, in the meantime i wil try the fuse, would it be the main blower heater fuse ,?
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
Try fuse 34.
ok i try them
So... obviously there's loads of different reasons for the battery going flat, but I've just done a battery reset on mine and I think it maybe solved my problem.
And I should clarify, whatever the noise is inside the dash it doesn't sound like the blower fan, it's more likely, I think, to be a fan for cooling the AV system or something. I think I've read elsewhere on here that such a thing exists - though I'm struggling to find the thread again!
Spoke too soon, just been back out to check the car and the hazard warning light is illuminated again and the backlight on the instrument cluster is back on (no picture, but you can see it's faintly lit).
hi there
Are you also seeing the hazard warning light backlit and the screens backlight also on?
no , nothing else is showing just the whiring noise. i did notice a couple of times that it changes pitch and uns slower with a sort of pulsing effect !!
