Home > Maintenance & Mods (L322) > 05 l322 td6 feels like the brakes come on while driving
deltic
Ireland 2005 Range Rover SE Td6 Bonatti Grey
Hi all when im driving at say 80 km about 2000 revs the car feels as if the brakes are applied the engine revs start pulsing up a bit but the car wont go with it cruise control wont work it happens every now and again i have checked the calipers thinking it was problem changed one at rear they are all good any help thanks
Post #575232 6th Dec 2020 12:02pm
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Had that at low speed in the wet HDC seems to do its own thing sometimes!
Cycle on and off and carried on no problem. Help got CAR OWNER VIRUS!
Post #575298 6th Dec 2020 10:13pm
deltic
Yes that seems to be the cause on one occasion the hdc light was on and would not go off but it drove ok at the time is there a cure or where to start looking thanks for the reply
Post #575365 7th Dec 2020 2:27pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
My money would be on rear passenger side ABS/Speed sensor, had the same symptoms in my TD6 Thumbs Up
Post #575374 7th Dec 2020 3:08pm
bleeperman
Likely abs sensor may clear itself but likely come back in the wet. Need a diagnostic to help decide which one to tackle. Help got CAR OWNER VIRUS!
Post #575375 7th Dec 2020 3:10pm
D3Jon
Agree re. the comments that it could be an ABS sensor. Failing that it could be the wiring to the sensor, rust on the ABS ring, or the ABS unit in the engine bay that can have issues.
Having said that - are all your tyres the same size? A mis-match would cause this issue, e.g. if you have 50 profile and 55 profile tyres mixed?
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #575476 8th Dec 2020 12:52pm
