![]() | Home > Technical (L322) > 4 Zone Climate |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
You’ve prob seen this already then. Can’t see much else....
| JNC Member Since: 23 Feb 2020 Location: UK Posts: 293
Yeh I saw that. Can't work out where those pipes attach near the engine bay. |
So it would seem the coolant feed and return to the rear heater matrix are just taken from the front pipes.
| D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 575
Is the auxiliary electric pump running? If that's failed you would see poor circulation to the rear matrix.
Im sure the pump is running. After much investigation on the vehicle and parts diagrams, I’m sure the temp is controlled by the rear matrix itself.
Ah, so if the supply pipe to the rear is getting hot, then that rules out the flow control valves in the engine bay.
To follow on from this turns out despite ruling out the crossover valve as I had only a few months ago repaired it, turn, it was still faulty.
Glad you got it sorted, and apols for not getting back re. IID values - I forgot. But looks like all sorted now, which is cool |
