Home > In Car Electronics (L322) > Digital display 3.6 TDV8
Tubsie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Barolo Black
As I only drive daily for a mile or so each way to the station daily I don't get much time to see if it has any quirks till I took her on a run last weekend when about 30 mins in the digitial display flashed up "Temperature shutdown" or words to that effect then completely off, it did restart but did this a couple of times during the trip.
I have recently changed the battery and it certainly didn't do it before as I've had a few long trips under my belt albeit in warmer weather but I cant see that that has much relevance.
So I'm hoping one of you can shed some light.
Cheers
Mark
Post #575441 8th Dec 2020 8:49am
mpirie
There is a fan behind the digital dash that is supposed to keep the display cool.
If the fan fails or is blocked, then you will get the temperature shutdown message.
Mike
Post #575453 8th Dec 2020 10:40am
Tubsie
Cheers I take it I'll need to dismantle the dash to get at it Laughing
Post #575473 8th Dec 2020 12:45pm
mpirie
Yes, but it's a lot of work to get to the fan so best make sure that it's failed first!
Mike
Post #575541 9th Dec 2020 10:16am
Tubsie
Hi Mike
Is there a way of verifying the fans operation without dismantling the dash?
Post #576245 15th Dec 2020 1:45pm
Baltic Blue
Read the W.M.
The fan is not near the cluster.
It is located near the steering column and air is forced into the inst cluster through a ducting.
It may be easier to get at ??
Also I think their is a filter that could be clogged.
Post #576255 15th Dec 2020 4:34pm
Tubsie
Thanks Mike
That certainly helps, though I'm suspecting it has more to do with the battery change that I have just carried out as it is currently shutting down pretty much as soon as I start her up and while it's not freezing outside here currently the ambient temp is low. I need to mod the battery terminal connections as the new battery was a bit bigger than the one fitted, so once
I've done that I'll clear any fault codes and see where it goes from there.
I have to say the new battery though expensive is bloody good the old one needed charging once a week as I was only doing a couple of miles a day
https://www.tayna.co.uk/car-batteries/yuasa/ybx9020/
Post #576312 16th Dec 2020 8:11am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I hope it keeps working for you, I've killed two Yuasa batteries. Got a replacement the first time, got a refund the second time. I'd never go there again. In my experience, they don't like being charged with my trusty ctek 9000.
Post #576315 16th Dec 2020 8:56am
Tubsie
Well fingers crossed can't fault it so far, and it has a 4 year warantee which will probably be about when I will look to upgrade the beast.
Post #576325 16th Dec 2020 12:31pm
